Home > Maintenance & Mods (L322) > Bent door frame
Danwilderspin
Bent door frame
I was filling with fuel yesterday and noticed the top of my driver door Fran is a bit bent. Is there any adjustment anywhere or do I wind the window down and try to gently flex it?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #649251 26th Nov 2022 8:53pm
i've read somewhere on the forum that placing a block of wood in certain places and pushing the door on said wood will bend the door into shape. ... - .- -.
Post #649255 26th Nov 2022 9:22pm
Danwilderspin
Cheers that sound like the build quality I’ve come to expect 😂 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #649261 26th Nov 2022 9:41pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Back in British Leyland days, it was a normal job in the pre-delivery inspection to bend door frames to get the seals to stop whistling air on a windy day. Standard tool was a three foot long steel bar with two pieces of round steel bar two inches long welded at right angles to the bar, one at the end, and the other leaving a 3 inch gap. Wind the window down and give it a tweak adjacent to the top of the wound down glass area. Most window frames had fixing bolts at the front of the door frame next to the A-Pillar. I have had to undo the top one to tweak the door frame to get a good seal. Trial and error job. You can put strips of hardwood each side of the frame to stop dents appearing if you need to put a lot of strain on the door.
Post #649309 27th Nov 2022 7:44pm
