![]() | Home > Technical (L322) > L322 - General suspension questions |
You would be better off putting 255/55/20 tyres on your original wheels... That vastly improves the ride quality sir... |
Lummox Member Since: 22 Apr 2022 Location: Doubtless Bay Posts: 10 ![]() ![]() ![]() |
Thanks. I've put 255/55/19s on - Pirelli Scorpion AT plus. I've only put 1000km on but so far I am impressed. |
The older non CVD system was as soft and as comfortable as it got for the L322. AFAIK the spring rate of the air bags are the same across all vehicles and the dampers are as well unless someone has fitted 'uprated ' ones. All terrain tyres generally have a stiffer sidewall so this may contribute to some increased ride harshness. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Don't be tempted to fit rear shocks from a 3.6 as they are longer than for other engines to go with the longer air-springs.
JayGee. Thanks for that. I thought that I read somewhere that the supercharged L322s had a sportier/firmer ride than other models, but after searching around, I have not found any confirmation of that. Maybe I just misread something.
I temporarily fitted RF10 in 255/55R19 from my D4 when I first got my L322 which I found quite harsh.
