![]() | Home > Maintenance & Mods (L405) > L405 headlamp upgrade |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Stick a better bulb in it sir... Osram do a good one |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
spaceman1000 Member Since: 10 Aug 2021 Location: Oxford Posts: 15 ![]() ![]() ![]() |
Is there a particular one you recommend? Cheers |
Osram do a good one… About £130 ish… 👍 |
Is there just one to pick from? Or is there an exact one you would use from their range? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
i found my cheap ebay 6000k hid bulbs helped with better road coverage as did a very small 'up' tweek on the headlight adjustment..
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
When you do let me know although they do seem a bit pricey : https://www.amazon.co.uk/dp/B08N56JYJT?tag...qvlapnhub0 Geoff |
i've been researching this led thing Geoff and have come to the conclusion that these from ebay seem a good bet,
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
Shame they can't spell "vehicle"
Johnh Member Since: 08 Nov 2011 Location: Rugby Posts: 44 ![]() ![]() ![]() |
Is the change to LED legal or will it fail the MOT |
Yes who'd buy from someone who can't spell veicle |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 166 ![]() ![]() ![]() |
this is plug and play, change them as normal bulbs. no need to remove ballast.In l322 it was 30 sec operation |
