![]() | Home > Maintenance & Mods (L322) > Sourcing Replacement Floor Carpets (Full Set) for L3 4.2L SC |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
Hi Les,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
The carpets will cost a lot from the dealers, also you need to strip most of the dash out to get the centre console out, also lots more trim to get the carpets up, it's a massive job...
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1212 ![]() ![]() ![]() |
As commented, breakers would be best, from memory when I took out my centre console I did not need to destroy my dash, ( 2006 model ), but I think you would have to remove the front seats etc. Maybe try a professional clean first and go from there if the result is not to your liking. To change the lot, a good trim tool kit ( about £14 ) would make life easier. |
You certainly don't have to "destroy" anything but you do have to remove parts of the dash to get the centre console out, it's also easier if you remove the lower dash panels.. You will have to take all the seats out and the lower trims on the A B and C pillars as well as the door thresholds
Les.Tansey Member Since: 14 Nov 2022 Location: Wilmslow Posts: 3 ![]() ![]() ![]() |
Hi All,
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
I put new LR mats in front and back a few years ago, highly recommended, it makes the car feel luxurious and special. 2012 L322 4.4 TDV8 AB low mileage - a peach
