Home > Maintenance & Mods (L405) > Heads up display.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Heads up display.
My 2013 SE does not have the heads up display.
Has anyone got an aftermarket one which they could recommend.
Retrofitting is not advised. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #647909 11th Nov 2022 6:18pm
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
I've only researched this online - have not committed as yet. I would suggest a simple display such as speed only. Some of the HUDs are quite tacky and have more lights than a Christmas tree.
Some only rely on GPS for speed (which is normally fine) others plug into the OBD2 port.
I suspect that they don't work too well in bright conditions and you need to stick a translucent patch to the inside of the windscreen.
Let's us know how you go!
Post #648266 16th Nov 2022 6:20pm
GrandadRob
Salisbury, I agree with the mass of unnecessary information some display. I want speed only.
Still haven’t found the one I want, will go and demo from a car shop. 2013 SDV8 4.4 SE Luxor.
Post #648274 16th Nov 2022 7:13pm
fisha
I have a factory fit one in my 640d …. I switch it off. It’s annoying more than it is useful once you get past the gimmick of it personally. I certainly would not be looking to after fit one , just don’t think it would be useful. V8 or else ...
Post #648293 16th Nov 2022 9:54pm
Just more evidence of how we're all different. Previously I'd have never spec'd HUD in an options list, but it was on the car when I bought it and having had it for a couple of years, now don't like being without it in other cars. Its great to have speed there without glancing down...but I also like the limit, cruise, and next junction flashing up when they become relevant. Certainly worth it for me. Mike - MPx
Post #648297 16th Nov 2022 10:50pm
Re: Heads up display.
I retrofitted a factory HUD dash to my 13MY L405 and fitted a cheap aftermarket £30-£40 HUD in the JLR box under the dash... Its a large black box with several mirrors inside. I believe through some form of witchcraft, the mirrors somehow take away the double/treble images you get from the aftermarket systems and the reason why you use the sticker on the windscreen... My wife now owns my old RR and loves the HUD system just like i did...
Hope that helps Thumbs Up
Post #648298 16th Nov 2022 11:09pm
Kot
Mine is factory fitted, I love it, would never buy a car without it. 2018 SE SDV8 4.4 Byron Blue
Post #648337 17th Nov 2022 11:59am
GrandadRob
Craig. How difficult is retrofitting a HUD 2013 SDV8 4.4 SE Luxor.
Post #648340 17th Nov 2022 1:30pm
No harder than changing a dash and a little fabrication of the HUD box to take an aftermarket solution…
Post #648350 17th Nov 2022 4:49pm
