Rear Window Mouldings DED500190 (LH) & DED500180 (RH) - | |
Hi Guys,
After months of searching around for the best one i could find, I am now the happy owner of a Santorini Black 2012 (L322) Westminster. One owner from new and a full 'no expense spared' detailed JLR/JLR specialist service history. A good starting point as i'm sure you will all agree.
Whilst pretty immaculate throughout, the previous owner clearly cared for it a great deal, i have noticed a few minor elements that i would like to correct and repair. I want to look after it as much as the previous owner has. All of the issues i have spotted are very minor cosmetic bits, which are certainly to be expected with age, but i'd rather deal with them straight away instead of letting anything get worse.
The main one issue i have noted is on the left and right moulding seals on the upper glass tailgate section. Both are starting to bubble slightly at the bottom corners and a bit cruddy with debris. I think I've identified the parts as DED500180 (RH) and DED500190 (LH) and just wanted to ask if anyone has had any experience fitting these? Whilst there are a multitude of YouTube videos for many other part installs and upgrades, i hadn't been able to find any showing how best to approach fitting of these parts.
Any help, guidance or suggestions on how best to approach would be kindly appreciated. Maybe I'll make an install video for reference
Thanks in anticipation
