![]() | Home > General > full fat sticker |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
ian, put it on the back of your left hand so when you go by on your cycle you can do your 'hand' thing and show the sticker... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3785 ![]() ![]() |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
Cleaner ? in answer to your question id say the kitchen is a good place to start "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
so , back on topic....i've put mine at the top of the rear screen not the bottom to basically avoid the rear wiper sweep.. |
hang ten ,i'll go and take one... |
there you go..
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
That looks good there. I'll have to do the same I think. FFRR TD6 HSE
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Does it miss the wiper sweep? |
mine ,where it is just touchs the bottom of the letter 'f'..a few mm's higher and it will clear..the last letter 'm' is cleared.. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
Looks smart at the top, I ordered an inside and outside one because I couldn't make my mind up - any idea's where to put the inside one or would two be too much - so many questions |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Not sure your GP would approve ![]() ![]() ![]() |
Ive ordered 2 and was going to put one in each rear 3/4 but not sure if that would be too much? |
you got to have one in the back window so that other FFRR owners can see it when they come up behind you or pass on the motorway.. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
The stickers are wiper proof, assuming you stick them on very clean glass |
