![]() | Home > Maintenance & Mods (L322) > Incorrect working PDC sensor without a fault |
Swap the suspect one with another, if the incorrect detection moves, then its a faulty sensor, if it stays at the same position, then either the harness or the module. |
Eventer Member Since: 17 Sep 2019 Location: Bremen Posts: 2 ![]() ![]() ![]() |
Hello and thank you for your prompt reply. I already bought a new one and changed each one to the new. It stays. Is there a seperate module for PDC in a 2002 L322? Where is it? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
Most likely the wiring harness for the sensors, well known failure point.... |
