![]() | Home > Finance, Insurance & Warranties > Not covered by Land Rover Warranty ? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8508 ![]() ![]() ![]() |
Maybe they consider the cracked covers as cosmetic, in which case they aren't covered...
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
We had both our hand brake motors replaced under extended warranty due to cracked covers, dealers told us is really common and if you don’t change them the water ingress ends up resulting in a new motor & calliper. I watched them do it, it’s literally a bolt and a plug!
RutlandBoy Member Since: 20 Mar 2022 Location: East Northants Posts: 31 ![]() ![]() ![]() |
Thanks for all the replies, interesting that you got them replaced under warranty - much of it appears to be down to the dealer by the look of it |
For ours the part was LR036573, the approval email doesn’t provide costs just says 1/2 hour labour for both sides.
Thanks for the information - I'll see if I can get them to do it - if not I'll do it - it will save problems later and potentially more work and cost !!!
Just be aware if you attempt it yourself you’ll need the car in brake service mode or what ever it’s called, I did it with SDD but I’m sure you can do it without just need to know the combo the service manual is in the Wiki |
Thanks, i will remember that - I have an IID so should be OK |
