Home > Technical (L322) > IID Tool query 8 speed reporting as 6 speed transmission
landy95
Afternoon all, slight confusion when I completed a 6-month oil change today on my 2012 4.4 TDV8, afterwards I had a play with my iid tool, does any have any idea why it tells me i have a 6-speed auto box? this is the scan i did of the ECU. It is defo 8 speed just seems odd?
Cheers
TCM-Transmission 6spd (Update available)
Assembly (F112)
Unknown -> BH42-7Z369-HK
Assembly (F113)
BH42-7000-AG -> None
Calibration (F124)
BH42-7J105-HJ -> BH42-7J105-HK
Hardware (F111)
BH42-14C247-HB = BH42-14C247-HA = Up-to-date
Serial
5801080540033671
Signal (F120)
BH42-14C389-HB = Up-to-date
Strategy (F188)
BH42-7J104-HF = Up-to-date Also own a 1976 Land Rover 101 3.5 V8.
Previously owned 1991 Range Rover Vogue 3.9 V8.
Post #646316 23rd Oct 2022 4:13pm
JayGee
It's same with mine. Worth getting the gearbox software updated at an indy or dealer with JLR workshop software as AFAIK it can't be done via the GAP IID tool 2012 TDV8 Vogue (L322)
Post #646317 23rd Oct 2022 4:31pm
this has been asked before..its a quirk of the GAP software.. ... - .- -.
Post #646319 23rd Oct 2022 4:39pm
DrRob
Ditto. Same on my IID Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #646320 23rd Oct 2022 4:48pm
GraemeS
I updated mine using the IIDtool.
Post #646331 23rd Oct 2022 7:49pm
landy95
How did that go? any issues? I have read problems can occur due to the gearbox wear allowances being forgotten. Have you noticed anything strange and did the iid tool report back you now have an 8 speed? Also own a 1976 Land Rover 101 3.5 V8.
Post #646334 23rd Oct 2022 8:50pm
GraemeS
Mine's update was done a few years ago but nothing untoward occurred afterwards.
Yes, it still reports as 6-speed.
Post #646336 23rd Oct 2022 8:57pm
JayGee
Software update retains the wear data and is not the same as a reset. 2012 TDV8 Vogue (L322)
Post #646344 24th Oct 2022 7:15am
landy95
I have just purchased the software update for my transmission ecu, Patrick at GAP has explained that Land Rover say it is mandatory to delete the adaptions prior to the update being installed. Obviously GAP are the experts on this but I would rather not delete the adaptions if others have updated successfully without deleting them. Has anyone done this update without deleting the adaptions? Also own a 1976 Land Rover 101 3.5 V8.
Post #648091 14th Nov 2022 9:47pm
Phoenix
I'd say JLR are the experts - it's their software. If it's mandatory to reset the adaptions, then there will be a good reason for it. Are you updating to resolve an issue or just to 'keep up with the Joneses'?
Post #648092 14th Nov 2022 9:55pm
landy95
It occasionally has the issue where it jolts momentarily almost as if it cant decide whether to change up or down a gear, I am wondering whether its worth the risk of potentially causing more problems with the update. Also own a 1976 Land Rover 101 3.5 V8.
Post #648093 14th Nov 2022 10:00pm
Phoenix
If the update specifically addresses the concern, then I'd say yes, otherwise, you could well be opening a tin of surströmming...
Post #648096 14th Nov 2022 10:08pm
JayGee
AFAIK it’s ZF base software. Indy did mine and didn’t reset the gearbox. They did it via the JLR workshop diagnostics so likley it would have told them to do it if it was needed. Software changes some gearbox behaviour and shift points but if you have hard shifts and bumps I’d first look at servicing it and possibly changing the mechatronic seals. Also try a throttle reset for some harsh shifting issues - ignition on, accelerator pedal to floor for 30 seconds, ignition off. 2012 TDV8 Vogue (L322)
Post #648118 15th Nov 2022 8:37am
landy95
Thanks for the comments, the shifts are 99% of the time really smooth with no issues, it very occasionally has what I can only describe as a hiccup, normally if it happens it is as I am approaching an island at speed if I remove pressure on the accelerator and then accelerate again as you do once you can see its clear without stopping it will clunk for milliseconds and sort itself out.
Almost like it was thinking of changing down then decides to stay in the current gear, its like no power momentarily. Also own a 1976 Land Rover 101 3.5 V8.
Post #648154 15th Nov 2022 4:37pm
JayGee
Has the box ever been serviced? 2012 TDV8 Vogue (L322)
Post #648159 15th Nov 2022 5:22pm
