Home > In Car Electronics (L322) > 2005 L322 RR Vogue; lost cig lighters, rear blower & hea
silentdrew
United States 2005 Range Rover Vogue 5.0 SC V8 Zermatt Silver
Hi everyone. I have a weird issue with my 2005 Range Rover Vogue - today I lost power to my cigarette lighters, rear fan blower and rear heated seats.
That appears to be it, the rear gates work, the rear heated window works, etc.
I recently changed the wiring so that the cigarette lighters were ignition controlled, taking out a jumper and adding a relay. That has worked for about a week so far, now this issue.
I’ve checked all the fuses in the back, they all look fine. Any ideas of what this could be? Thank you for helping me if you can, best, SD
Post #645724 15th Oct 2022 5:07pm
silentdrew
Hi everyone, I got this working. Many thanks to @nicedayforit for the help.
I was focusing on the back fuses and relays. I applied 12V to the relays to make them close, then tested the terminals for continuity. They were working fine. So then I tested the rear fuses, they were all looking ok but some didn't have power. So I figured there might be a fuse in the front box that feeds those fuses. Long story short, if you 2005 L322 rear blower, rear heated seats, cig/aux lighters don't work, check Front Fuse #2. Its a little 5amp fuse that took me all Saturday to find.
But, I learned some stuff today about my vehicle, about this community, and about multimeters.
cheers, SD
Post #645742 15th Oct 2022 9:16pm
