Home > General (L460 2022) > Coolant |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1410 |
No loss on my 4.4 v8 so does seem strange |
4th Oct 2022 9:24pm |
Christonabike Member Since: 29 Jan 2022 Location: North East Posts: 95 |
Thank you.
4th Oct 2022 9:34pm |
All vehicles 'use' coolant to some degree - that's why it's topped up at service.
4th Oct 2022 10:06pm |
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 278 |
1.5 litres seems quite a bit I have had a new landrover use a bit but not that much. It was definitely at the correct level on delivery? MY23 PHEV HSE
5th Oct 2022 6:48am |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
Can you smell that distinctive sweet smell of coolant under the engine bay after a run? Carpets damp? Problem is that the sound absorbing foam under the carpet tends to soak up any coolant.
5th Oct 2022 7:55am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
Both my 322s (4.4 BMW petrol and 4.4TDV8) lost coolant.
5th Oct 2022 10:31am |
That's all been done and there's nothing telltale that would indicate a leak.
5th Oct 2022 6:29pm |
jackwaite1402 Member Since: 06 Oct 2022 Location: Middlesbrough Posts: 1 |
Hi Christonabike,
6th Oct 2022 7:02pm |
And yet I have a few contacts 'on the floor' in JLR workshops who say your contacts huge issue, isn't... |
6th Oct 2022 7:10pm |
It’s a D350 Jack. Looking good since it was topped up but will keep an eye on it. Interesting to hear, thank you. |
6th Oct 2022 8:01pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 824 |
To be fair, Jack's sources may be completely wrong....... However, they may also turn out to be absolutely correct!
7th Oct 2022 8:58pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
In answer to your question, Ive only had a small reduction and that was over 21000 miles and even then it was a small water bottle amount so Id say something is very adrift at 13k! all smug in my new plug!
12th Oct 2022 2:20pm |
I would have thought that a low coolant level would have been picked up on the PDI by the dealer. Having been through a similar issue and passed from pillar to post, I hope its not an issue for C'bike. Niggly issues spoil the enjoyment of what is otherwise a great car. |
12th Oct 2022 3:54pm |
