Home > Maintenance & Mods (L405) > Advice re trim 'mudflap trim'
comports
Hi all,
Just a quick question as I seem to have a lose bit of trim on my car - its a small section of trim that sits at the base of the fron wing, behind the front wheels and has the front mud flap attached to it
I just want to know how it attaches as I don't want to just pull it off if it needs clips/tape etc.
ps. I do love my 'black' car
Thanks Ash
2016 SDV8 AB
Post #644753 4th Oct 2022 2:36pm
AnotherMutley
The painted bit?
Its clips, but you may need to take the mudflap off to get it back on and before you do that, you've got to take your front wheel off for access to the fittings for the mudflap, they're a pain to fit.
Post #644766 4th Oct 2022 5:08pm
comports
Hi Mutley.
Yes the painted 'square' - it just seems to be a but lose so it its just clips, I'll get some new ones.
Thanks Ash
2016 SDV8 AB
Post #644789 4th Oct 2022 7:20pm
JCW
Here’s the back of the panel showing the mounting clips / locations, should help when removing it Thumbs Up
Post #644790 4th Oct 2022 7:53pm
AnotherMutley
Theres some red plastic fir tree type clips and two bolts that hold the textured plastic part to the inner wing. The plastic bits that fit into these will need painting to match the colour of your car. I vaguely remember having to drill them, there were templates in the fitting kit from LR, its not a nice job.
These might help
http://accessories-instructions.landrover....2104382150
Post #644792 4th Oct 2022 8:40pm
