![]() | Home > Maintenance & Mods (L322) > What can I put on an electrical connector to waterproof it? |
S60R Member Since: 23 Mar 2022 Location: West Sussex Posts: 50 ![]() ![]() |
There are a few waterproofing aerosol sprays.... I had a demo of one that was hugely impressive.... no idea how but they sprayed a light bulb and lamp holder with it, plugged it in to an RCD socket, turned it on and dropped it in a bucket of water! It stayed lit and didn't trip.... I'll try to find the stuff....failing that try WD40 or a hot glue gun? It has worked for me. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Any non-conductive maintenance spray such as Duck Oil (used widely on electrical connectors on boat engines).
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1582 ![]() ![]() ![]() |
I use Electrolube SGB Grease G2X on contacts of mains garden light connectors.
Nyogel 760G is the LR approved solution (you can get it in 5g sachets with a LR part number), mainly used to prevent contact fretting but also prevents water ingress (if you use enough of it!) due to it's high viscosity.
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Sorry to burst your bubble but that "test" is meaningless - RCD's require an imbalance of current in the live & neutral to operate - unless the bucket the water was in was metal & sitting on a conductive path to earth the RCD would not trip - bet they did not do a "before & after" spray demo. &, FWIW these "plugtop/in-line" RCD's are often insensitive - I've failed enough in the past. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
As ever amazing help from you all.
