![]() | Home > Maintenance & Mods (L322) > How to fix a loose wing mirror |
Excellent guide Andrew, got this one coming up on my nearside following a whack by a branch !! .
I had similar problems, that the mirrors would move under heavy braking, or acceleration. I just needed to tighten up the 4 screws from the first pic (even though there not there). If yours are tight then it must be deeper in the internals and andrews guide will be priceless! |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 ![]() ![]() ![]() |
I'm glad it's useful.
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 ![]() ![]() ![]() |
I have looked and looked but I cannot tell how to remove the plastic cover. it looks like to me the bottom piece is in two halfs and not just a cover peice. Do i detach the hole section that is closes to the face of the glass? i would hate to break such an over priced item. |
Which plastic cover? Do you mean the one under the hinge section or the plastic glass surround? |
I am referring to the one under the hinge, it connected to the arm that goes back to the window. It appears the side mirrors where modified from 2004 to 2005, they have different part numbers. See thread on other form. I am not sure how to post pictures here. http://www.rangerovers.net/forum/viewtopic.php?f=2&t=28029 |
the cover has 2 legs. one is quite long an the other short. Use a small screwdriver and lever it off. Be firm but don't go mental. There is a small slot to get the screwdriver in.
Thanks for your help, i will try it this weekend. |
Top effort for the guide Andrew! Used it today with great effect! Stan can we get this into the wiki? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
wiki'ed... |
Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 37 ![]() ![]() ![]() |
Just ripped mine apart, the pins that are supposed to hold the mirror in place are missing..
SLAMG Member Since: 11 Dec 2017 Location: Vancouver Posts: 4 ![]() ![]() |
Hello there! anyway to get the photos back? I need to do this as my mirrors are super loose on my 2007 l322 supercharged.
