Home > Maintenance & Mods (L322) > Rear Caliper Refurbishment
Buckie1967
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Buckingham Blue
The front calipers were refurbed around 2 years ago before I acquired the vehicle. I decided to check out the rear calipers and they were pretty poor and on one side the piston was stuck though the braking still seemed okay to be fair (I appreciate the fronts account for around 70% of the braking ability)
Post #643226 17th Sep 2022 8:00pm
Buckie1967
Anyhow I have removed both sides and the refurbishment is underway.....for both rear calipers.
Brembo Rear Brake Discs x 2 (365mm 210467036A) £60
Rear brake pads EBC DPX2068 £19
SOE 500030 Rear Pad Sensor £8
Rear RH Flexi Brake Hose LR058026 (ABS SL 6703) £23
Genuine Rear LH Flexi Flexi Brake Hose LR058025 £24
4 x rear Caliper sliders & rubbers (LR017032) (Bigg Red BRH1480AX) £14
2 x 45 TRW Pistons (Bigg Red BRP234510) and seals x 2 £20
2 x Bleed Nipples, 2 x Rubber boots for pistons £15
BPCS Sand blasting/powder coating (£17.50 per caliper) £35
1 litre of DOT 4 Brake Fluid £10
4 x New Caliper retaining bolts £8
Sorting these rear brakes out will be around £236 but well worth it imo. Should future proof them for a few more years.
Post #643228 17th Sep 2022 8:10pm
