![]() | Home > Maintenance & Mods (L322) > Stiff gear lever movement |
I recently posted on this. You need to get under the car and spray loads of WD40 on the gear linkage on the side of the gearbox and easily visable on drivers side I think. Drain/Level plug is on the other side. THe Linkage is VERY prone to corrosion especially when a car is left unmoved for a period. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Corrosion after a week is a bit poor!
It builds up and is a common problem normally highlighted after the car is left standing for a while...
ken0204 Member Since: 07 Mar 2010 Location: north essex Posts: 7 ![]() ![]() |
Thanks Gaz
Let me know how you get on but it worked for me |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
i shall have to remember this for when mine gets stiff... |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Having suffered from WD40 use in the past - it's technically a water dispersant not a lubricant - so some marine/ agricultural waterproof grease or ptfe spray might be better http://www.screwfix.com/p/no-nonsense-ptfe...id=1999825 ... |
WD40 does work but I agree there are better lubricants. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
He hey! This seems to have fixed my gear lever problem too, Thanks Gazellio: http://www.fullfatrr.com/forum/topic4657.html? [EDIT] spoke too soon, still not "PARKING" properly . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
