![]() | Home > Wheels & Tyres > Tyre advice please ... |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 123 ![]() ![]() ![]() |
Probably is under inflation. You might be able to get a few more miles out of them, but with winter approaching is it worth it? Probable better to just bite the bullet and get new boots all round. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
Did your car come from factory with turbines?
manxaircrest Member Since: 17 Jan 2014 Location: Isle of Man Posts: 42 ![]() ![]() ![]() |
Hi ... yes it had the turbines on from new ... I have the original suppling dealers receipt.... down its life its ended up with these davanti's on it .... my plan is to replace with perelli scorpion .... my point was that to have both edges wearing to 2mm and the centre still at 6mm .. when app 8mm is new ... I'd say under inflation .. however the tpms setting is for light load ... and is ok .. if I change setting t heavy / normal (whatever it is) .. and run them harder do we feel the ride / handling would be compromised given the already 22 inch wheels ... very best ..
If you're expecting the outer edges to somehow lift off the road and only run on the centre of the tyre, it won't work.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
you can get 4 wheel alignment checked free at places like kwikfit/ Halfords service centres, but they charge to adjust it. this can lead to premature edge wear, so you'd want that checked before buying premium tyres. I paid 70 pounds for 4 wheel at Halfords, after ringing kwikfit, and was told its 150 pounds to align all four, with rear toe adjust.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I had some Divanti’s on one of my non LR cars and they were awful and also wore incredibly badly, the seller had clearly put them on for the MOT prior to sale. They did roughly 50% of the mileage of the Pilot Sports I replaced them with, and as above were pretty much ditch finders.
I think I know the place you mean - the cost is basically the price of one decent tyre, well worth it in my opinion. Even more so if you've had work done that will span the life of several tyres. |
