Home > Off Topic - Other Cars > Rear diesel drive belt
Gagglemo
I have been told that the high pressure diesel pump belt at the rear of the engine requires body off and there fore leave it alone,it’s a 2012 SDv6 2012 Range Rover sport hse,any advice muchly appreciated
Post #641451 30th Aug 2022 5:51pm
you'd be better of asking on the sport forum,
https://www.rrsport.co.uk/forum/index.php?...713ee8379e ... - .- -.
Post #641452 30th Aug 2022 6:03pm
knwatkins
It doesn't have to be done with the body off. It can be done in situ but it's a whole lot easier with the body off. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #641453 30th Aug 2022 6:20pm
I’m assuming it’s a similar job to the D4 given that they are almost the same underneath, in which case mine was done in situ albeit on a 2.7 but afaik it’s basically the same..👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #641474 30th Aug 2022 9:27pm
Mikey
Rear belt is most definitely not a body off job. Shouldn't really take any longer than 2hrs or so to replace
Be aware though, that it is timed Thumbs Up
Post #641493 31st Aug 2022 4:44am
