Home > Maintenance & Mods (L322) > Final Stage Resistor FSR recommendations
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi all,
I’m replacing my FSR as the one I have only works for settings 0 to 3. There are quite a few cheap ones for sale like this, but it’s been frustrating me for a while so I purchased another albeit different one from Amazon (Brand -KOVEBBLE), only to find it was the same. To be fair there were some other reviews that also indicated it only works on low setting levels.
I called JLR Milton Keynes and they wanted £176 + VAT, which seems crazy. I know others on here had them from stealers albeit a few years back for sub £40.
Any recommendations of where to buy one / which brand that 1) lasts a decent amount of years and 2) is low price ?
By the way. - one to avoid is this one
Many thanks -------------------------------------
MY 2012 4.4 TDV8
Post #640729 24th Aug 2022 11:56am
johnboyairey
i bought a secondhand original one on eBay, for £12, it was exactly same as old outgoing one. -still working! wanted to prove it was this that was faulty.
Post #640744 24th Aug 2022 2:39pm
Googs
Australia
I got one from fleabay that was meant for a BMW, and was supposed to be original but when I got it it didn't have and part numbers (BMW) on the side, It did fit and its working so far, that was a few months ago.... Still seem to get same soft codes on scanner, as long as it works....its winter on the other side. 😢
Post #640748 24th Aug 2022 3:47pm
Well worth the extra price for a genuine one unless you like changing them... mind you it doesn't take that long to change... IMHO the pattern ones don't last long... you maybe lucky though...... Thumbs Up Pete
Post #640750 24th Aug 2022 4:14pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
I had a couple of cheapies that worked but prevented full shutdown.
Bit the bullet & bought a genuine one from JLR - it was around £50 a few years ago, but it worked as it should.
Post #641219 28th Aug 2022 1:14pm
V8 Bob
I fitted a Meyle 314 880 0000 to my 2012 model about 3 years ago and it’s been fine. It is specifically for BMW X3/5 but is identical to the JLR part they cost about £36. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #641409 30th Aug 2022 9:09am
