![]() | Home > Maintenance & Mods (L322) > Diesel virgin |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Having recently come over to the dark side I have questions.... I'm reading all I can on here but can't find much about how a regen works...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
Obviously many on here are more technically able than me but the diesel Range Rovers I have had (two) do mainly short journeys and I've never encountered any DPF issues. Obviously I've been filled with FUD about the whole thing but it has been a none event for me. I do a decent journey about once a month. Geoff |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Pete,
Thanks for the info Kevin, Geoff and Mike, an IID is on it's way as we speak...
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
I just traded my 4.4L engine for the 3.00 litre diesel.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Had mine 3 years now Pete and no warnings so far, (hope I don’t regret saying that). I do short journeys to work, circa 6 miles each way on 30 MPH roads. I try and give it a good run at the weekend including faster roads, IE the local bypass where possible.
https://www.fullfatrr.com/forum/topic60984.html
Mike,
Don't worry about how it works unless it shows a problem. 2012 TDV8 Vogue (L322) |
Bill and Diesel Dave, apologies, I missed your posts..!! Thanks for all the info, I'm a bit of a sponge at the moment...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Yeah, the soot will burn off naturally if it gets warm enough regularly. It’s all about the temperature of the exhaust.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
Don't worry about it unless you get a warning light.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
...and if you do get a warning light, the causes are pretty well documented on this site and there's plenty of members who can help. 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks, yes, lots of help on here, I do like to know how the cars I drive work and this is the first "modern" diesel I've had.. |
