Home > Technical (L322) > L322 Range Rover 2005 only starting with Quick start spray
johnmaambo
South Africa 2005 Range Rover Vogue Td6 Barolo Black
Hi All,
My RR just stopped starting normally from nowhere :blub. Here is what i have done and checked.
1. Checked my battery and all is okey
2.Plugged a Foxwell Machine and it brought up this error code(P0380 -Glow plug relay failure - glow relay defective)
3. I changed the Glow plugs but still not working.
4. I changed the relay but still not working.
When i use the quickstart spray,it does start although its a hard start. After starting it i can drive it all the way BUT when i switch off,i have to use quickstart again.
Please someone,point me to what might be the issue.Am now clueless as to what has happened.
I would also want to find out if there is anything that the quickstart spray will damage because of its constant use when starting the vehicle.
Many thanks in advance.
Post #639672 15th Aug 2022 10:39am
