![]() | Home > Technical (L322) > Aerosus front air springs |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Yes, 8mm Allen key to hold and spanner to tighten. I literally cannot get it any tighter or I fear something will shear. Christian.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8396 ![]() ![]() ![]() |
I've just changed a front bag on mine and it has sealed with only a "normal" amount of torque on the top nut...
Opened a return to Aerosus now and ordered BWI bags, I cannot be dealing with this nonsense.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
That's quite a tight fit |
When I removed the old ones they literally just fell off, this is another level!
Hopefully the bwi bags will give you a better result |
Still cannot get the airbag off, it's well stuck on there.
Try clamping the top swivel section in the vice and striking the top of the strut, if you've not already done so |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3155 ![]() ![]() ![]() |
Could you use a big puller on the edges of the metal band around the air bag with the centre of it on the top of the strut?
Tried everything and eventually had to cut the bags off.
