Home > Maintenance & Mods (L322) > air suspension fault
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Hi all
one of these days on a 400kms trip into the south of Portugal with more than 35ÂșC, at the midle +- appears on my cluster the message "Air suspension fault".
I turn the steering lock to lock and didn't solve. I remove the battery negative termional and nothing. Than I remove the fuses 30 and 57 which concern to the suspension and the message disapear.
Now I feel the suspension stiffer.
At home I connect the AllComs and no errors on the suspension.
Could this incident decalibrate the suspension?
Where can I find the correct height for the suspension?
Vehicle: 2002 L322 Td6 Vogue
Cheers
Post #639617 14th Aug 2022 10:07pm
Post #639634 15th Aug 2022 7:00am
A.Pires
suspension fault
Nicedayfavorit
Thank you very much. That chart helped me a lot.
With the Allcoms I calibrate de suspension (was completly out of range) and now is completly different and much more smooth.
Once again, thank you very much
Cheeers
Post #639892 16th Aug 2022 10:28pm
