![]() | Home > Maintenance & Mods (L322) > Transmission fluid |
What exactly is the issue with the lower gears?. Have you checked the fluid level? 2012 TDV8 Vogue (L322) |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
I saw a post on here from RRPhil stating that he would only ever use the correct ZF ATF fluid.
I used the Smith & Allen to do a couple of double flushes prior to doing a filter change - but I put Lifeguard 6 (ZF) in at that change.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1269 ![]() ![]() ![]() |
All good points and I thank you.
How does the gearchange feel when you use the paddles? is it positive or still a bit 'unsure' as to which gear it is in?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
So, ATF fluid wise, oils are made to a specification. So, in theory it doesn't matter which brand you buy. Everyone has their view but specifications are specifications. Any good brand will ensure their oil complies with them.
Just a point on specifications - these are the minimum performance specifications the oil has to meet to literally 'make the grade'. As has been pointed out many times, the modifiers which are added to the oil are over and above the specification, and often what differentiates the subjective 'quality' of the oil, of course, these additives are a closely guarded trade secret and part of the reason for a cost uplift - not just the cost of the additives, but in part, a recoup of the development costs, and yes, a decent profit margin.
I rarely use the paddles except occasionally when towing my caravan but only in the top gears. I've never used them from a stand still so will give it a try tomorrow and see what happens.
I got mine through work (sorry!) try Duckworth LR or Talexin on fleabay, they sell the genuine stuff.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Cheapest I found on eBay was:
Thanks Rambles. They've only got three litres left. Might have to buy the odd one here and there. Moneys a bit tight at mo. |
