Home > Maintenance & Mods (L322) > HVAC system clean
Phoenix
HVAC system clean
The HVAC system on my 08MY was a bit smelly, not especially musty, just.... smelly.
Traditionally, the fix is to use the antibacterial spray, put the aircon on full with the recirculation on and leave for some period of time. Having seen these in (in)action in various cars and concluding that all they generally do is kill the bateria in the headlining and give a bit of as chemical smell for a few days / hours, depending on the quality & quantity used, I tried something different.
There is no indication in the WSM of where the recirculation air inlet is on the heater box, best guess is somewhere between the heater box & the bulkhead, I could have smoke tested it to determine exactly but the smoke doesn't smell great. By removing the centre console 'cheeks' the sides of the heater box are exposed, there is a gap against the bulkhead, this is most likely where the recirculated air is drawn in so I put a can of the aircon antibac spray either side, setting the temperature to ambient, fan to ~30% and recirculation to manual 'on', the idea being that as the system works on the 'reheat' principle, this would guide the antibac spray through as much of the heater box as possible whilst pushing it through at a slower rate so as to treat the internals, not the air and cabin surfaces.
Stage two was to treat the heater matrix and the evaporator to a foam bath - not as weird as it sounds, Fortron ( https://fortron.co.uk/shop/aerosols/fresh-zone/ ) and others produce a foaming product to clean and disinfect these parts, usually applied by a long tube down one of the dash vents, which I was going to do until I saw this...
That is a metal plate with seal on the N/S condensate drain (there is one on the other side too) I removed it and used a short (~300mm) extension tube to get the foam forming deep in the area I wanted it, The instructions are to let the foam dissipate over 10 minutes before switching on, well, it seems that is to let the foam revert to liquid and run out of the condensate drains bringing all the crap and crud with it, because that's exactly what happened.
All that was just over three weeks ago now, the aircon and (just to see if it had been positively affected) heater have no smell at all, it's like driving a new-ish car again.
It might seem like a bit of a faff, (the Fortron stuff can't be bought online but there are alternatives) but if you have a persistent smelly HVAC system, the above worked for me.
Post #639056 8th Aug 2022 6:28pm
Well spotted on those two, I must admit I have used the anti bac aerosols in the past and read the instructions, ignored them, and put them in the front foot well pointing at the HVAC unit... Foam stuff looks good to.... Thumbs Up Pete
Post #639062 8th Aug 2022 6:56pm
Phoenix
I think the foam did most of the 'heavy lift' in cleaning the heat exchangers and of course the enclosure, the aerosols probably had more effect on the ducting to the vents.
However it worked - it worked.
Post #639064 8th Aug 2022 7:30pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Did you take the clear plastic cover off of the drain tube & spray up the tube / ducting?.
Post #639095 9th Aug 2022 11:12am
Phoenix
Its stainless steel, but yes, it looks like plastic in the photo... Its held in place by a T20 screw. I did spray the foam in from both sides but to be honest, you could probably do it from just one side. Make sure you put the cover back on as soon as you finish spraying the foam in so the muck goes out of the drain tube and not on the carpet!
Post #639112 9th Aug 2022 1:55pm
Gsxr1250dave
LR TIME on the tube just coverd this using the foaming spray with a long straw down every air vent
Post #639129 9th Aug 2022 6:50pm
Phoenix
The potential problem with that approach is that most HVAC systems default to 'all flaps closed' when shut down, I can't honestly say whether the various iterations of the FFRR follow this scheme or not, getting the foam into the area where I wanted it by removing the caps shown above did get the results I was aiming for however.
Post #639130 9th Aug 2022 7:09pm
JayGee
Luckily mine doesn’t smell. 2012 TDV8 Vogue (L322)
Post #639135 9th Aug 2022 9:09pm
Phoenix
Good for you. For those who have smelly aircon due to lack of maintenance / use, the above may help.
Post #639136 9th Aug 2022 9:34pm
