Home > Maintenance & Mods (L405) > Cool Box Switch
Fifth Horseman
horse86 wrote:
there's the one with black internals and the snowflake button that has 2 blue LEDs......then there is the one with the white internals and have the flip switch that lights up green when on. No one knows which is which yet ppl love to say what they "think it is/have"
The one with the white interior and rocker switch is the cooler - uses a Peltier heat pump
On post-facelift models the one with the black interior and push button switch may be either a cooler or fridge. The cooler uses a Peltier heat pump and the fridge version works like a small domestic fridge. Listen closely to it when it is d=running =, if you can hear something like a small compressor then you have the fridge.
Engineering part numbers for the versions are:
Cooler version - JPLA 044K02-Ax
Fridge version - JPLA 046N01-Ax
Post #644332 29th Sep 2022 6:29pm
