![]() | Home > Maintenance & Mods (L322) > Headlight Restoration |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
I just wondered if anybody had any experience of these headlight restoration products which are on the market.
Never used any specialist products, l just use TCut always worked for me. |
I've used the 3M 39073 kits quite successfully on a couple of vehicles, use a sealant afterwards though. A quick wipe over with https://www.amazon.co.uk/gp/product/B00A3S1RGU/ every few months seems to keep them clear, I've been doing that on my previous vehicle since 2018 (still got the same bottle of polish!) and they haven't yellowed or dulled at all. |
Thank you all for your advice - To be honest, nicedayforit is probably right and T-cut would probably do the job perfectly well, that said, I've decided to go for one of these kits which I think will give similar to what I think JCW is describing, plus it also gets 4.7/5 from 342 reviews:
That looks very similar to the 3M kit, except I think the 3M one has another intermediate polishing step. similar price though.
Any polishing compound will work including toothpaste but the main key to success is using it via power tool and not elbow grease. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
My local car parts store do this for a tenner.
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 ![]() ![]() |
Gary, did you use a sealer after? I’d be interested to know how long they remain clear with and without putting a sealer on after they’ve been polished? |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
If you're keeping the vehicle which i suspect you are, the best way i have done it is clean off with some wax & grease remover wipe down then with 800 grit on DA sander sand it down all over when you're done wipe with Wax 7 grease again wipe off mask off hood and any think else you don't want to paint and apply 1.5 coats of 2K clear and it'll be like new for a couple of years.
