Home > For Sale & Wanted > towbar and armature
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
towbar and armature
FOR SALE
brand new ball type towbar and armature for 2008 vogue
never been used
complete with locking bolt, nut and pin and keys[b]
including polystyrene boot holder and strap
�120 + postage
[/b]
Post #69017 17th Jun 2011 2:16pm
oodathort
Hi can you confirm postage costs
Thanks
Post #69037 17th Jun 2011 4:06pm
ric355
There are three parts to the towbar system on a RR:
- The armature is the very large and heavy steel bit that spans across the back of the car
- The receiver connects into the square fitting in the armature
- The towball fits into the receiver
Are you selling all three bits?
Post #69042 17th Jun 2011 4:46pm
AMD
If you can pick all that lot up for �120 including the armature, someone would get a great deal. The kit normally goes for �400 on flea bay. Postage in the UK would be �50 at a guess, the armature is very heavy. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #69053 17th Jun 2011 5:49pm
pretlove
do you reckon this will fit a 2003 ff as most of what ive seen on fleebay are for all models from 2002 upwards
pm sent Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #69056 17th Jun 2011 5:57pm
ric355
Pretlove the armature on a 2003 model is different to the 06 onwards model but the towball and receiver are the same.
AMD I'd be surprised if for that price it is all there including the armature, hence I wanted to verify. I'm not actually a buyer since I just had a brand new lump delivered myself the other day, but I wanted to help save a misunderstanding.
Post #69067 17th Jun 2011 7:35pm
Johnte
Can I be in queue for this please - if no one in front of me wants it..
Post #69092 17th Jun 2011 8:47pm
pretlove
Big Cry no good to me then "RANGEISM WILL NOT BE TOLERATED"
Post #69112 17th Jun 2011 10:25pm
tierneyj
Ireland 2005 Range Rover Vogue Td6 Java Black
I fitted an O7 tow bar on a 02 L322 the only modification I had to get done was to relocate the exhaust mounting brackets which a local welder did for EUR30 other than that its straight forward...
Post #69123 18th Jun 2011 7:42am
My guess is its everything apart from the armature as its a two piece kit easy to get confused with part names...
Post #69131 18th Jun 2011 10:45am
nbunney
Ian
Do you have the 2 metal bits that need to be fitted when you remove the armature?
If not I do Whistle
Post #69281 19th Jun 2011 8:14pm
iancollins
sorry
its the receiver, the square bit that fits to the armatur with bolt and nut with clip
and quick release towball
all bolts, nuts and pin are there + 2 keys and orange bung.
also included is the polystyrene box and bracket that fits in r/h/s rear footwell in boot
i guess postage would be about �15
Post #69314 20th Jun 2011 9:09am
