![]() | Home > Maintenance & Mods (L322) > 3.6 TDV8 Air Con system pressure ? |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
As the weather's been warming up recently ( |
Update & problem solved !
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Pressure isnt the way to assess the gas content, it has to be done by weight. The pressures youre talking about seem way too low, all aircon units Ive dealy with are 160 psi and above. BMW i3 Electric Car
American, quite old but still relevant in terms of understanding pressure in airconditioning systems.
Phoenix,
How can you 'top up' a system without knowing the correct charge weight and the current charge? additionally, at best it's irresponsible to top up a known leaking system, it's also possible for a leaking system to draw in air (which is non-condensable) if the leak is on the low side or the high side if the restriction orifice (or on some vehicles, the thermostatic valve) is blocked, which will artificially increase the low side pressure.
You may be right, or possibly different gasses used, most of my experience is with home aircon rather than automotive. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Advice please, running a TDV8 4.4 and suffering from the normal issue of AC not cutting in until after 5 mins and then intermittent working during running. Possibly the normal issue with PCV sticking. I took the car into my local garage today and explained to the receptionist when she asked what the problem was and told her I thought it was the PCV and that the AC cuts in after 5 mins.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
No it wouldn't work with a small charge of refrigerant in, how did they measure it though, did they evacuate the system to a recovery cylinder as that's the only way to measure it.... |
Allegedly they discharged it and measured it. They then said the recharged it and tested system and as it wasn’t working discharged and recharged again and concluded compressor shagged. |
They may be confusing the RCV in the compressor with the Thermostatic valve on the bulkhead just before the pipework passes through to the cabin. These are known to be slow to react and can be the cause of 'slow starting' aircon (on any vehicle, not LR's especially) The system would not operate with only 20g of refrigerant in it, let alone give any cooling.
Is the RCV the same as PCV that gets talked about on here. So am I correct in that a faulty PCV will still be linked to slow starting and intermittent operation. If I switch off and restart, getting fuel etc. it will take 5 mins again to kick in. |
Probably, although the terminology is wrong, the refrigerant control valve controls the flow not pressure of liquid refrigerant.
Many thanks for your input. Much better informed for discussions tomorrow. So if the RCV not functioning correctly, no AC I presume.
