![]() | Home > Maintenance & Mods (L322) > Fuel filter change problem |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 54 ![]() ![]() ![]() |
did the filter on our 4.4tdv8 a few weeks back
You need to bleed it using the Schrader valve under the engine cover - easier if you have someone to turn the ignition key on & off. |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
Ah. I saw that valve and wondered what it was. When I worked out that it was in the fuel system, I prodded it open with a small screwdriver and some air came out. I will work on that in daylight tomorrow. Many thanks. |
Stuff plenty of rags around it or you'll smell warm diesel on the engine for weeks after....
Quite a bit of air came out. It then fired up without hesitation. Brilliant. Many thanks. |
