Home > Technical (L322) > Steering wheel buttons
ivan1566
United Arab Emirates 2012 Range Rover Autobiography Black 5.0 SC V8 Santorini Black
Hopefully one of you superstars can help with my latest issue.
On starting the car I intermittently get no power to any of the buttons on the steering wheel, including the horn. This causes cruise and forward alert not available and amber gearbox fault warnings.
After a minute or so of driving the power comes back to the buttons and if I stop and restart the car the faults clear.
I have had the steering angle sensor, clock spring/rotary coupler and brake pedal switch replaced and the wiring checked and contacts cleaned. The battery is only around 6 months old and new alternator fitted.
Any ideas please as I’m still at a loss..
local Indy suggests maybe a software upgrade is required, hesitating taking to the stealer if this will not be the fix.
Thanks
Post #636110 5th Jul 2022 12:15pm
