![]() | Home > Maintenance & Mods (L405) > Rear Seat Stuck in down position |
karba78 Member Since: 21 Mar 2020 Location: Plaisir Posts: 105 ![]() ![]() ![]() |
you may have to short the wires that go to the electronic box below the foot under the carpet in front of the seat.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1308 ![]() ![]() |
Try moving the front seat all the way forward then try again with rear seat 2018 SE SDV8 4.4 Byron Blue |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
My right rear portion does the same..
rockodrama Member Since: 29 Jun 2022 Location: Alabama Posts: 5 ![]() ![]() |
this rear seat is giving me a massive pain LOL. Today, Ive managed to remove the front seat, to work my way under the carpet to remove the rear seat module (looked a little corroded so i cleaned it up), and struggling abit trying to read the wiring diagram to see which harness/wire i need to try to give some power to. I will keep reviewing the manual over next few days. In the meantime, I'm going to put everything back together and pray to the LR Gods your trick works @marcochezzi |
No luck, I think I’ve tried to jump every wire I see in the schema that says recline/incline with no results. Will insert pic if anyone has any guidance. It appears someone has already spliced something on the wire harness that goes into the module. My last attempt is gonna be take the right rear seat module out swap it and see if the seat lifts if that works I’ll try to wire both seats to the same circuit. So both buttons raise both seats. Will keep updated. |
Sorry to hear my trick did not work for you rockodrama.. Keeping things super simple have you checked all the fuses in the back when you remove the right boot panel, some of those fuses have to do with the seat electronics.. one never knows.. Before I discovered my little trick purely by chance I would remove certain fuses which also somehow reset the system and allow my seat back to return… but it’s a proper pita in my opinion, much less practical than on my 322, which is why I was super happy to discover my little trick.. Just by the way, the other day I needed to carry some large kit which necessitated complete removal of the rear seats, there are 2 wiring connectors under each seat cushion.. I’m not entirely sure what the connectors are for, but unplugging the connectors stops all seat operations, just maybe one of those connectors are problematic, problem is getting to them with the seat down is not possible, certainly not for me anyway… Apologies of the poor photo quality, it’s 1.30 am and using the iPad as a camera with no flash… |
Still trying smh. Ended up going through the back of the seat to try to turn the axel that controls the recline/incline can't seem to move it with vice grips either direction or find a release on either side. |
