Home > Maintenance & Mods (L405) > Strange noise from nearside
mpirie
Hi guys, I had a strange noise start when turning right in my car earlier today.
Accelerating through a right turn there's a grinding noise, like a tyre rubbing or a failing CV joint. No noise on left turns or straight driving.
Could it be related to the ARC system running low on fluid? I have corrosion in the front pipes and am waiting to get them replaced, so carry a bottle of power steering fluid with me.
I top up the reservoir regularly but have seen air in the system while the engine is running.
Any suggestions?
Thanks,
Mike
Post #635462 25th Jun 2022 8:42pm
number76
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
https://www.fullfatrr.com/forum/topic57020...+box+noise 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #635484 26th Jun 2022 7:55am
cass
It's worth checking that a front brake shield hasn't come loose?
Post #635491 26th Jun 2022 10:17am
mpirie
Thanks guys. Thumbs Up
Mike
Post #635510 26th Jun 2022 4:05pm
mpirie
Just had the diagnosis from the main dealer on my leaky pipes and creaking on right turns.
It turns out that the loss of fluid replaced by air in the ARC system is the cause of the right-turn noise.
Glad i was sitting down when they gave me the the repair cost! Big Cry
Mike
Post #636159 6th Jul 2022 10:09am
DrRob
Find a specialist independent instead e.g MMP in Dundee. Cheaper and better quality work Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #636164 6th Jul 2022 11:03am
My car has just been in for a service and the groaning and rubbing type noise has been diagnosed as leaky front ARC pipes.
The problem seems to be these parts are on back order and could take months to source, plus I’m number 6 on the list to get them!
Does anyone know a source for these at all? Got - 2017 SDV8 Autobiography in Loire Blue
Post #691793 2nd May 2024 7:28pm
mpirie
Can you get to the leaking section?
Mine was on the offside wheel-well downleg, behind a rubber clamp Rolling Eyes
Surely the leaking section could be replaced by fresh steel pipe and compression fittings?
Mike
Post #691803 3rd May 2024 5:25am
I’m picking the car up later, so I don’t know yet where the corrosion is but they say it’s in the place it always goes, behind the front wheel.
I don’t believe it’s as easy as replacing a brake pipe but not sure the reasons why. Got - 2017 SDV8 Autobiography in Loire Blue
Post #691804 3rd May 2024 6:11am
