![]() | Home > Maintenance & Mods (L322) > How easy is it change steering rack gaiters? |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
A little google and here is a possible solution...
It's just a light LMP grease, something like clutch spline grease would do it - you don't need that much, it's just to lubricate the bore of the rack and the inner ball joint on the 'drumstick'. If you can't find a motor factors that'll sell you a small tube of it, try C Bennis supplies and services in Southport, they sell small quantities of all manner of special lubricants.
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
There's so little grease used inside the gaiters it's hard to imagine it being noticable with a split gaiter.
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 ![]() ![]() ![]() |
I’ve rechecked the power steering fluid level and it’s spot on? Once I’ve finished the oil cooler change, I’ll have another look to see if there’s anything else that might be leaking? Ive rechecked the drive shaft to see if that’s split and throwing grease around but the grease would be everywhere if those were split? Don’t you just love range rovers!!
