Home > Maintenance & Mods (L322) > Phone Cradle Removal
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi,
Hopefully a really easy question to answer for someone, but I have a old siemens phone cradle in the centre arm rest and wanted to remove it. Is it just a case of prying it out or is it held in with screws somehow ?
Cheers Thumbs Up
Post #635132 21st Jun 2022 5:09pm
Discotigger
I had a phone cradle in my old 2005MY TD6, might be slightly different to yours but if you unlatch and raise up the centre armrest and look underneath it there was a tab that you pressed to release the cradle.
Post #635145 21st Jun 2022 8:14pm
p38arover
Australia
Dunno if this will help. I did mine a few years back when the GSM network closed here. Scroll down the page to the text and pix at https://www.fullfatrr.com/forum/topic21468...p;start=60 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #635158 21st Jun 2022 10:35pm
batfink
Thanks for those ideas, I'll take a look and see how I get on. Thumbs Up
Post #635187 22nd Jun 2022 3:22pm
batfink
So I just got a bit of time to go and take a proper look and managed to sort it.
First off, lift the centre cubby lid and underneath there's x4 Torx screws to remove
Once removed, push down on the handle and pull the top section of the cubby upwards to split the two sections
unplug the connector
Pry the two arms either side of the phone holder apart
Slide the phone cradle out
Now I can get that Land Rover Mini Umbrella to put in there. Thumbs Up
Post #635190 22nd Jun 2022 4:13pm
