Home > Maintenance & Mods (L405) > Anyone fitted LR deployable sidesteps to a 2017 L405 |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 669 |
I'm not sure if this any help, but when i fitted my dss to my l322 i did disconnect the battery and once everything was in place bar fitting the steps, i had to press the button once when the battery was reconnected and then turn the ignition on but don't start it then hold the button in for 5 seconds which in turn deploys the steps ready for fitting. I'm not sure if this is the same for L405 models, you can actually download the manual somewhere online but can't think where. However, saying that another guy on here fitted steps to his 2010 model L322 and found that the wires in the plugs going to the module were in the wrong place as his steps went in reverse, as in door opens, steps go in, shut door steps go out. I have actually read somewhere else that sometimes the module could be the wrong part number so worth checking you have the right module part number for the L405. And if I'm not much mistaken, there are 2 different looms for the L405 just like the L322 which i found out the hard way. Sorry i can't be much help on this but giving it a go with my info may just help. |
17th Jun 2022 8:20pm |
logiedurno Member Since: 17 Jun 2022 Location: Aberdeenshire Posts: 4 |
Thanks for the info. I know there are at least three different looms for the L405 dss depending on the model years. I have the correct figment loom for the car and the correct module so I will have a go at disconnecting the battery as per the schematic instructions ( they don’t specify having to let the ecu know there are sidesteps fitted which they do for some models so I presumed it should be plug and play) my vehicle has the infotainment screen so again, I don’t know if that would automatically update without plugging into a Land Rover sdd laptop to tell the vehicle it has steps fitted. Don’t you just love technologically! |
17th Jun 2022 8:32pm |
ciprian Member Since: 23 May 2021 Location: Essex Posts: 3 |
Hello guys,
28th Jun 2022 7:59pm |
who did you use to do the programming? |
28th Jun 2022 9:17pm |
I managed to find a good guy close to where I live,in Essex.It cost me £200 |
28th Jun 2022 9:40pm |
4th Jul 2022 7:12pm |
