Home > Maintenance & Mods (L322) > Brakes : What’s this green tube?
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Please would someone be able to say what this small green tube is. It appears to be going to the brake callipers on the front near side ( passenger side ).
There does not seem to be an equivalent on the front Off side ( Drivers side ).
I noticed it was badly kinked and may even be torn. I’ve done a running repair for the time be but am concerned about having a developing problem as I’m off on to Cornwall on Friday ( 500 miles return ).
Any advice much appreciated.
 TDV8 4.4 2012
Post #634508 13th Jun 2022 11:50am
diesel Dave
Pad wear sensor wire. They’re about 20 quid for a new one and plug into the black plastic box in your picture then are a push fit with a small metal clip on the brake pad, they are on one side only hence o/s missing Thumbs Up
Post #634509 13th Jun 2022 12:05pm
Ramblin Man
Thanks @Diesel-Dave. Is the green tube a protective sheaf or is that the whole thing ? It seems so flimsy that I wonder if there is a electrical wire inside the PVC tube. TDV8 4.4 2012
Post #634511 13th Jun 2022 12:13pm
dingg1
Wire inside, once pad wears down to the wire, it goes open circuit and brings in your dash light
Post #634512 13th Jun 2022 12:15pm
Rambles
The green sheath is the whole thing.
£10
Part number for MY11 4.4
SOE500030
Post #634513 13th Jun 2022 12:18pm
diesel Dave
Yes its a protective cover, there is a wire in there but its only a sensor wire, IE when the sensor on the pad touches the disk the ECU gives you a message you have worn pads. I never like to say you’ll be ok to leave it with brakes, however the worse you could get is a false worn pads warning, or none at all if broken then the pads touch the disc with a scoring noise as in the old days.
Post #634514 13th Jun 2022 12:20pm
Ramblin Man
Thanks everybody; I’m feeling reassured! TDV8 4.4 2012
Post #634515 13th Jun 2022 1:01pm
Rambles
I think the way the sensor works is that the car needs to detect a complete current through it.
Contact with the disc usually breaks / damages the end of the sensor, and breaks the circuit.
Continuing until you are metal on metal will see the end of the sensor ground to dust - the yellow warning triangle will still be on.
Once you get the brake warning light, you will need to change the sensor, as it’s connectivity has been broken
Driving without a sensor will give you a brake warning light (well, mine did)
You should be able to re-use a sensor where the warning light has not come on. As it’s circuit has not broken.
Post #634519 13th Jun 2022 1:31pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Mine was fine with one of the sensors off for about a month - no warning light or anything.
Post #634558 13th Jun 2022 8:34pm
