![]() | Home > Maintenance & Mods (L322) > Battery/alternator issues - do these voltages look healthy? |
The voltages look OK for a managed charge system (as on your vehicle), the voltage varies - not just for battery SoC but also for ambient temperature and engine load, you say you had a replacement battery fitted, is it the same type as the old one? the wrong chemistry can cause problems.
l3222019 Member Since: 09 Oct 2019 Location: Brunei Posts: 8 ![]() ![]() |
Managed charge system? I didn't know I had one of those. I had pulled a bunch of fuses for the entertainment system etc around 3 years ago as I was worried there was a parasitic drain on the car. Sometimes when I locked the car the entertainment screen would be on. Could the pulled fuses be affecting the managed charge system?
The charge system controlled by the Engine Control Module based upon various factors, your journey length as an average suggests there are a fair number of journeys shorter, I've been to that part of the world a few times and car journeys are high electrical load due to the weather (it's always odd being in mid-30's temperature with the wipers on due to the humidity!)
Thanks a lot for your detailed response, it was very helpful and made sense.
Thanks, I've uploaded the charge system diagnostic instructions for the LM which you may find useful.
