Home > Maintenance & Mods (L322) > Plastic paint work
roel2018
Belgium 2017 Range Rover Autobiography SDV8 Carpathian Grey
Plastic paint work
Preparing for a weekend job. Painting the plastic panel near the bonnet. Any advice or what paint I should use? Or just a new one? Part no.? Also painting the wiper arm.
Thanks!
 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch
Post #634246 10th Jun 2022 10:58am
Same process as this, just chose your top coat colour...
https://www.fullfatrr.com/forum/topic27260.html
Wipers are satin black, the black plastic under the wipers will not accept paint, it has too much wax in it, a trim reviver will make it look a lot better... I use this stuff, not cheap but it lasts a couple of years, works on all black plastic exterior trim...
https://www.gtechniq.co.uk/shop/auto/wheel...-restorer/
EDIT:
Just read your post again, are you talking about the black trim or the silver trim... if silver trim then follow the above post, if the black trim then get the gtechniq...
A new black trim is around £200...!!
You will need a wiper arm puller to remove the arms from the spindles, they will be very tight.... Pete
Post #634252 10th Jun 2022 12:12pm
