Home > Technical (L322) > Aircon problem
Page 1 of 3 123>
Paddocks67
Aircon problem
Hi guys,iam having aircon problem,I have plugged in gap iid tool and the fault 0x9 refrigerant pressure fault.has anybody any idea as to what that refers too,cheers pat
Post #634162 9th Jun 2022 2:20pm
millerj90
I don’t specifically know that fault code, but there is a known problem with a pressure valve/sensor mounted on the A/C compressor itself.
You can change the offending item, but you need to remove the compressor to gain the clearance. Once you’ve done that, it’s just a easy to replace the whole thing.
Post #634185 9th Jun 2022 4:53pm
cass
have you checked the gas pressure?
Post #634191 9th Jun 2022 5:35pm
Phoenix
Refrigerant pressure can be misleading, especially on warm days, you need to recover the refrigerant and compare the amount to the specified charge amount.
Post #634193 9th Jun 2022 5:42pm
cass
It's a good place to start looking as no gas = no aircon
Post #634194 9th Jun 2022 5:51pm
Phoenix
If there's no pressure then yes, if there's some pressure, it can and has led people to think it's not a lack of refrigerant (and therefore a leak) that's the problem.
Post #634195 9th Jun 2022 6:03pm
Paddocks67
Hi lads.i have put a can of stop leak in and a can of refrigerant,the gap iid tool says it has 40 bar of pressure
Post #634205 9th Jun 2022 7:47pm
Phoenix
It's way too high, I'd suspect the sensor or the connection to the sensor - are you sure the reported measured value is reliable?
40 Bar (580 PSI) is a lot, even for a blocked system, I'm surprised the pressure relief valve isn't / hasn't operated. It does sound like some default value has been set, try disconnecting the sensor and re-read the value.
As a guide, with the aircon and engine off
Deg. C R134a PRESSURE (PSI)
0 30
10 45
15 55
20 70
25 80
30 100
35 115
40 130
Post #634206 9th Jun 2022 8:07pm
Blimey, that's 580psi, IIRC maximum should be somewhere near 160psi Pete
Post #634207 9th Jun 2022 8:08pm
Phoenix
Up to 250 PSI with the system running normally and an ambient of ~40 deg. C.
Post #634209 9th Jun 2022 8:12pm
Paddocks67
I will check again tomorrow,to see if the reading has went down any,
Post #634211 9th Jun 2022 8:17pm
Paddocks67
Hi lads I have checked again,it still says 40 bar on the iid tool,and still have refrigerant pressure fault 0x9 showing up,cheers pat
Post #634461 12th Jun 2022 7:43pm
Paddocks67
Also as soon as i turn urn aircon on,the fan kicks on right away,is that normal I can't remember if it done that before when it was working,cheers pat
Post #634462 12th Jun 2022 7:46pm
Phoenix
It does sound like a faulty pressure sensor TBH, try disconnecting it and see what reading & DTC you get. The fan running constantly is because it sees the pressure as excessive and is trying to cool the refrigerant sufficiently to lower the pressure.
Post #634465 12th Jun 2022 8:01pm
Paddocks67
Thanks for the reply,I will try that tomorrow and see what happens,cheers pat
Post #634466 12th Jun 2022 8:06pm
Page 1 of 3 123>
