![]() | Home > Maintenance & Mods (L322) > Replacement / recon engine needed... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Playing devils advocate here....he might be saying engine has gone so he can buy it off you cheap, replace the cooler and then have a decent motor for pennies.... |
Not worth doing the oil cooler if the cause is something else and it now sounds like the garage know what's what with LR's. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
Can you take or drive it to the workshop where it was recently for a second opinion? Providing there's adequate oil in the sump and no water in the oil then the engine shouldn't be any worse off for the drive. |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
Apparently the oil pressure was so low that the shells have been damaged and timing gear slipped a tooth causing valve damage. So it isn't looking good. If I can't find a very sensibly priced replacement I'll advertise as it and buy a newer one. I need one in 6 weeks for a trip around Spain so not going to hang about too long.
There are some nice ones advertised in the for sale section here at the moment which may fit your requirements 2012 TDV8 Vogue (L322) |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Secondhand engine for the 4.4 tdv8, is about £5k, plus fitting. Worth throwing some money at what you’ve got, if it’s still running, and driving. |
