Home > Maintenance & Mods (L322) > Am I missing covers or something?
Danwilderspin
To the sides of my climate units I seem to have an unsightly 4mm gap but can’t work out why as everything is tight?
Last the rear seat hinges look like they should have some kind of covers missing - am I over thinking?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #632526 22nd May 2022 11:45am
Merchy
Mine's a 2006 Vogue, so there may be differences, but......
The rear seats have covers on them (Blue, to match the interior ) You cannot see the hinges.
The trim at the side of the HVAC panel has a very small gap on mine, the gap is the same left and right, it looks like your side panel is not clipped in correctly. It clips into place at two points at the side of the HVAC panel, with a holding screw down in the foot well. Hope this helps.
Post #632540 22nd May 2022 2:17pm
dhallworth
The side cheeks on your heater panel just look like they’re not seated properly. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #632546 22nd May 2022 2:52pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Thumbs Up For the comments above.
Post #632556 22nd May 2022 3:50pm
Danwilderspin
Right… took the cheeks of - lined up the plastic pin and plast expanding plug thing on both side and it’s still the same - the gap seems wider at to top… any ideas 😂 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #632725 23rd May 2022 10:40pm
Highroller
Dan, they can be a little trickey to line up & can take a couple of attempts.
You need to line up the front of the trim at the top with the surround & ensure that the trim clip is located correctly ( then locate with a light thump).
No need to worry about the back of the panel, as you have quite a lot of movement & it's only held in by the one torx screw.
Good luck Paul.
Post #632758 24th May 2022 9:10am
