Home > Technical (L405) > L405 Reversing Camera Issues…..
Bigfella70
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Morning all,
Seeking advice, please re non working reversing camera on my recently acquired 2016 model year L405. This is the camera with built in washer.
Basically upon selecting reverse no image appears on screen. Also on the motorway an error message triggered for blind spot monitoring unavailable. I’m presuming this is because of the lack of the camera / feed issue.
I’ve searched previous threads and seen issues where an LR dealer has thrown a new camera on only to find it was a wiring issue.
Is there a troubleshooting process to test the camera unit, feed wires etc and try establish what the actual issue is rather than gunning parts at the issue hoping something works?
Thanks in advance.
Dave. Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
2004 Mercedes R230 SL350
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #631669 15th May 2022 5:15am
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
one of te reasons it can happen just because you have one defect in your parking sensor system, either sensor or wiring loom. it messes up completely the rear camera. 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #631676 15th May 2022 6:43am
Bigfella70
Thanks for that. One thing I’ve noticed is that upon pressing the camera symbol beside the infotainment screen, nothing at all happens. I’d expect the display to go into camera mode……. Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #631863 16th May 2022 4:40pm
karba78
those camera do do work either, nor the parking assyst system if one sensor is messed up 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #631868 16th May 2022 5:26pm
Bigfella70
Parking sensors seem to work ok.
No camera display at all.
I’m wondering if there’s a way to test the camera off the car, and whether there’s a process to test continuity of wiring etc…… Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #632548 22nd May 2022 3:22pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I had this when I got my 2014 car many moons ago. (don't get me started on Lookers Bishop's Stortford who misdiagnosed it for over a month and damaged the car whilst it was in with them - it was so bad we nearly ended up in court).
Anyway mine had the same "no image in reverse" fault, it was a break in the wire at the tailgate/body intersection - eventually LR warranty also fitted a new camera at the same time.
Lookers Bishops Stortford wanted to take the rear glass out to fix the wiring (completely unnecessary fyi), and the fault was eventually rectified at another LR service centre by changing that section of wiring look between the body and the tailgate. Been perfect ever since (appx 4 years).
Hope that helps 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #634118 9th Jun 2022 8:11am
karba78
thank you
it happened to be the front sensor loom which was disconnected.... probably loosely connected previously during maintenance
thank's for looking into it though 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #634120 9th Jun 2022 8:26am
Bigfella70
Thanks for the heads up on the wiring issue and location of the potential issue.
Hoping to get this looked at in a couple of weeks and test the camera, wiring feed etc. Will keep the post updated. Thumbs Up Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #634271 10th Jun 2022 3:38pm
