Home > In Car Electronics (L322) > Best/easiest place to get ignition live in boot?
Danwilderspin
Hi all - this really - I need one for my exhaust valve control - there must be one there but my meter didn’t find anything on the fuse panel (unless I’m a moron) so thinking splicing something? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631533 13th May 2022 4:56pm
JMC
I'd have thought that the easiest is the cigar lighter socket in the boot....
Edit: Scrub that - only applies to the 2010-12 model. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #631546 13th May 2022 6:45pm
It may or may not be relevant to a 2007 model but earlier cars had an ignition controlled cable as part of the feed to the trailer socket. The cable was 0.5mm and was green / yellow and could be found in the loom running above the rear fuse board position. If you find this cable and intend to use it to splice into bear in mind it can only be used to switch a relay for additional equipment, it’s fused at 5A. Thumbs Up
Post #631553 13th May 2022 7:08pm
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
You may be right JMC
My 2007 SC has the cigar lighter in the boot. The dogs use it all the time Rolling with laughter
Douglas 2007 4.2SC Buckingham Blue
https://www.fullfatrr.com/forum/topic63319.html
Post #631560 13th May 2022 8:31pm
Danwilderspin
Thanks - the cigar sockets in the car semi to be ignition lives but the boot one is permanent - can that be changed with relay did I once see?
If not I’ll splice that green wire Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631563 13th May 2022 9:17pm
I’m sure I read somewhere that in spite of manuals saying the rear cig lighter is permanent that it does switch off when car goes to sleep. Have you got anything with a light you can plug in and watch through the window?
Post #631565 13th May 2022 9:21pm
Danwilderspin
I have a tyre compressor I could put the lead out the window - how long until it sleeps? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631567 13th May 2022 9:32pm
Not sure. 10 mins rings a bell but others will know better.
Post #631568 13th May 2022 9:38pm
You could put a USB adapter in and run a long phone lead out the window to see how long it stays on charge. Not sure how long a compressor will run with no load before overheat cutout. 2007 4.2SC Buckingham Blue
Post #631569 13th May 2022 9:41pm
Danwilderspin
I’ll just turn it on and off every few mins Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631570 13th May 2022 9:57pm
p38arover
Australia
There is one on the 2003 model - I use it to turn on the dual battery controller. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #631577 14th May 2022 5:15am
mjdronfield
The cig lighter stays on with the earlier cars. 2010 MY cars don’t, goes off when the car goes to sleep. I know, cos I have a 12v cooler box that won’t stay powered on 🤣. Did on my TD6.
I’m not 100% sure, but I think the little red light near the gear lever goes out when your car is asleep…. If it helps you testing your sockets looking through the window.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #631592 14th May 2022 9:32am
Danwilderspin
Yea cig lighter in boot is not ignition although car ones are oddly …
Plans to use the 20amp wire switched on by the trailer module if it works… Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631784 15th May 2022 9:02pm
