Home > Technical (L322) > gearbox service kit zf6hp26 question |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
need to order a gearbox service kit , question is do I need the correct suffix following the 26?
30th Apr 2022 11:19am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1766 |
LR007474 |
30th Apr 2022 11:51am |
Cheers, sump pan and 7lt of zf lifeguard 6 on its way from amazon.de, 160 quid
30th Apr 2022 12:59pm |
Turned out only the pan was damaged, valve body not touched, (phew ) box was serviced 30000 miles ago, oil was quite dirty imo, no metal on magnets which was good to see, noticed they hadn't changed the mechatronic sleeve at last service, in hindsight I should have changed bridge seal and valve body seals, but thought about it too late, box has been changing no issues so hopefully it will continue to next filter and oil change |
11th May 2022 1:42pm |
