Home > Technical (L322) > Coolant bleeding
sean mullane
Ireland
Coolant bleeding
Hi . 2012 tdv8 4.4 . Hi recently changed the engine oil cooler and now have only cold air blowing from the heaters. How do I bleed the heater matrix ? Thank you
Post #631099 9th May 2022 6:41pm
kevinp
I would let the engine idle with the expansion cap off for a while.
Do you know there is a bleed screw on the expansion tank as well?
Post #631139 9th May 2022 10:09pm
garyRR
I'd follow the process described in the workshop manual (wiki section of the site) because, it details step by step what you should do to re-fill and bleed the system.
Yes, there is a bleed screw on the top radiator hose to the right of the expansion bottle. 2015 Range Rover Autobiography 4.4 SDV8
Post #631187 10th May 2022 1:19pm
