Home > Maintenance & Mods (L322) > Oil leak 2011 4.4 TDV8.. not oil cooler
ChrisPy1966
Hi All,
I have a worsening oil leak on my 2011, 105000mile 4.4TDV8. Started off as the odd spot on the drive a couple of months ago now a much large "patch".
This morning I took the pollen filter off expecting/hoping to find the oil cooler caked in oil, but the cooler and pipes seem completely dry.
Further investigation seems to suggest that the leak is somewhere near the front of the engine on the RHS (drivers side UK). Looking down through the engine, I can see that there is oil on the drive shaft boot, and also on the top of the last steering column joint before the steering rack (as far as I can see with a torch). I havent yet been able to get under the car, but the worsening oil patch on the drive would indicate it is somewhere near the driveshafts, but obviously I could be being folled by the undertray. I am currently losing approx 500ml of oil every 200miles or so. Very slight smell of hot/burning oil occasionally (outside the car), but I think the leak is below the exhausts.
Any ideas of where to look further? Is everything at this level beyond DIY?
Thanks in advance...
Post #630625 4th May 2022 12:09pm
DrRob
Could be a few things. Oil pump plug sometimes leak or it could be turbo in that area Big Cry
My advice would be to get it to a specialist for a proper look-see on a ramp with engine sump guard off etc.
I only ever use Glenrands now. They do a delivery/collection service or a loan car. Speak to Ross and tell him I sent you. www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #630631 4th May 2022 12:36pm
ChrisPy1966
Cheers.
Glenrands isnt too far from me. I might seee what theyl charge for a look. I am really hoping it isnt the turbo !!
Post #630632 4th May 2022 12:56pm
DrRob
Keep us posted. They run a good outfit. Mine is currently there having a few things sorted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #630638 4th May 2022 2:12pm
ChrisPy1966
Booked in next Tuesday. I will update when I have a diagnosis.
Post #630682 5th May 2022 9:35am
DrRob
Post #630690 5th May 2022 10:30am
ChrisPy1966
So apparently, it's leaking from an oil scavenge pipe at the back of the engine. One of those "we've never seen one leak from there before" problems! If I'm lucky, it can be fixed in situ for around 800 .. but if I'm unlucky it's an engine out job!
Great service and comms from the guys at Glenrands so far though. I will be using them again.
Post #631237 10th May 2022 9:09pm
DrRob
New one on me that!
Glad you got a diagnosis and fingers crossed it can be done in situ...
Good to hear that Ross et all looked after you. Customer service is their #1 priority Bow down
Keep us posted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631260 11th May 2022 6:49am
DrRob
Is it all fixed now? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631487 13th May 2022 9:07am
ChrisPy1966
Got it back on Friday.
They managed to do it with then engine in, but they also found a small split in teh turbo oil hose, so fixed that aswell. Total bill came to just over £900. As I had mentally budgetted for £2k, I treated it to some new tyres on Friday too. I guess I'm comitted to keeping t for at least another year now!
Just need to get the residual olil off the block paving, and I can forget about oil leaks now hopefully
Glenrands did a great job on this, and I would thoroughly recommend then to anybody in the Surrey /Hampshire area. Thanks Dr. Rob for the initial recommendation!
Post #631837 16th May 2022 1:37pm
DrRob
Good to hear Thumbs Up
Top lads there Bow down
What tyres did you go for? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631841 16th May 2022 2:02pm
ChrisPy1966
Pirelli Scorpions. For no reason other than that is what came off, and I was quite happy with them, so thats what I put back on !
Post #631931 17th May 2022 8:37am
mjdronfield
Think that’s what they left the factory with, unless another choice was made. I went with those when I replaced mine.
Hopefully getting it back how you like it now.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #631932 17th May 2022 8:56am
ChrisPy1966
I am committed to it now having spent the best part of £1800 at the weekend. So I will be looking to do some cosmetic work (seats), and also fix the DAB (no reception) in the next few months. Then I will be happy !
Post #631936 17th May 2022 9:22am
DrRob
Seats? BTrim in Enfield are allegedly superb Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631954 17th May 2022 10:40am
