Home > Technical (L322) > Vogue MOT Fail ? |
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 39 |
If it is less than 3 months since the MOT was issued then you could contact the garage who did the MOT and say you will be in touch with DVSA about it (They will take this seriously) unless they offer to put it right, But think the garage should take the car back, was the dealer the same garage who did the MOT?
2nd May 2022 8:32am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1183 |
Ouch that looks bad, as for legal rights, other people on here will have more knowledge and be able to advise you.
2nd May 2022 8:44am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1375 |
The hindquarters of the 322 are structural and not an easy/cheap repair. I agree with your instinct to get rid.
2nd May 2022 9:44am |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 119 |
If you’re happy with the rest of the car, I’d be tempted to let them fix it. That way you’re safe in the knowledge that it’s been done and isn’t going to cause you any issues going forward. That said, I’d also see what else is on the market for the same sort of money that I’d get back for rejecting the car in case there are any better options. |
2nd May 2022 9:56am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
There’s a guy on YouTube with the same issue (along with many other people).
2nd May 2022 10:19am |
nfm Member Since: 09 Apr 2019 Location: UK Posts: 19 |
I inspected a RR for a friend where the garage “fixed it” six months before for the (now) vendor and it was rotten again. If you go down the fix it road then at the least ask for wip photos of rot cut out / new metal let in etc otherwise you could be a victim of a bodge. |
2nd May 2022 3:16pm |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
Sorry to see that. Unfortunately I think you will find the other side will be just as bad!
2nd May 2022 4:04pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Before you do anything l would be inclined to get under the car , just behind each front wheel, and remove the plastic cover that is part of each wheel arch liner. I took mine off when l got the car and found a garden behind each wheel arch. Luckily l was able to clean each area out and there was no corrosion. If you find corrosion of the cills at the front as well l would dispose of the car by whatever means.
2nd May 2022 4:09pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Id have a loom at your rear subframe too if it’s that rusty!
9th May 2022 5:41pm |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 189 |
I had exactly the same on my car, so I watched eBay for a few weeks contacting anyone that was breaking an L322 up to 2012. After a number of them came back saying there's were rotten too, one came back with photos showing all good and solid. So I bought them off him, he cut them out and shipped them on a pallet to me for £250 from memory. I then got a local welder who cut mine out and replaced with the good ones for £130. |
9th May 2022 7:13pm |
