Home > Technical (L322) > Brake pedal fade |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Technically, what you're experiencing isn't fade, but pedal "creep".
1st May 2022 5:29pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Thanks so much.
1st May 2022 5:34pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
You have a leak somewhere…. Had similar when my rear brake pipe split…. Pedal went further than normal, which then stuffed the seals in the master cylinder as the piston had not gone that far before and garage thought there might me some type of “rust lip” or similar inside it…. As mentioned above.
1st May 2022 5:55pm |
I stamped on brakes some 2 month ago and it burst a rusty pipe. I replaced pipe (front to rear). Bled all up and has been fine for last couple months.
1st May 2022 6:02pm |
Ah, ok. I stamped on the brakes when mine split.
1st May 2022 6:27pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Master Cylinder, not brake fade. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
2nd May 2022 6:32am |
Thanks so much guys
2nd May 2022 9:54am |
It’s caused by fluid leaking past the seals, it doesn’t leak out if the brake system, just bypasses back to the resovoir. BMW i3 Electric Car
2nd May 2022 10:28am |
Yeah it done it to me driving home just after my last post.
2nd May 2022 10:36am |
